Einleitung
Replace the keyboard!!
Ersatzteile
Keine Ersatzteile angegeben.
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  5. Using a T6 Torx Screwdriver, remove the two screws. The motherboard will now be loose from the front case.
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  6. Using the spudger, flip open the clasp that holds the data ribbon in place.
    • Using the spudger, flip open the clasp that holds the data ribbon in place.
  7. Pull out the ribbon.
    • Pull out the ribbon.
    • The keyboard will disconnect from the phone.
Abschluss
Clement Poisson
24 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 13-23, Maness Winter 2010 Mitglied von Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Mitglieder
16 Anleitungen geschrieben
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,422
