Zum Hauptinhalt wechseln
Palm Treo 600 Logic Board Replacement
Was du brauchst
  1. Palm Treo 600 Logic Board Replacement, Back Case: Schritt 1, Bild 1 von 1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Logic Board Replacement: Schritt 2, Bild 1 von 2 Palm Treo 600 Logic Board Replacement: Schritt 2, Bild 2 von 2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Logic Board Replacement: Schritt 3, Bild 1 von 2 Palm Treo 600 Logic Board Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Logic Board Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  5. Palm Treo 600 Logic Board Replacement: Schritt 5, Bild 1 von 1
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
  6. Palm Treo 600 Logic Board Replacement: Schritt 6, Bild 1 von 1
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  7. Palm Treo 600 Logic Board Replacement: Schritt 7, Bild 1 von 2 Palm Treo 600 Logic Board Replacement: Schritt 7, Bild 2 von 2
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
Abschluss
Cal Poly, Team 13-23, Maness Winter 2010 Mitglied von Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,502
