Einleitung
Steps to follow if you want to replace the logic board. Also needed if you want to access the camera.
Was du brauchst
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
