Einleitung
If your Palm Treo phone call audio is muffled or not working at all, use this guide to replace the earphone.
Be aware that this guide only provides a solution to the Palm Treo cell phone, and the replacement of its earphone.
Note that the guide uses two different screwdrivers, and an iFixIt opening tool. Having these tools on hand are essential to completing the guide.
Was du brauchst
Position the phone so the screen faces down.
Remove the stylus found on the back of the phone.
Hold the button in the middle of the phone's back to remove the battery cover.
Slide the cover down to remove it, and set the cover aside.
Lift the edge of the battery, separating contact points, and pull out as pictured.
Remove the round, rubber cover to expose a screw that will be removed in the next step.
Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
Pull out the earphone by grabbing the black rubber piece identified in the picture.
