Zum Hauptinhalt wechseln
Palm Treo 650 Microphone Replacement
Was du brauchst
  1. Palm Treo 650 Microphone Replacement, Battery and Stylus: Schritt 1, Bild 1 von 1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Microphone Replacement: Schritt 2, Bild 1 von 1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Microphone Replacement: Schritt 3, Bild 1 von 2 Palm Treo 650 Microphone Replacement: Schritt 3, Bild 2 von 2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Microphone Replacement, Case: Schritt 4, Bild 1 von 1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Microphone Replacement: Schritt 5, Bild 1 von 2 Palm Treo 650 Microphone Replacement: Schritt 5, Bild 2 von 2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Microphone Replacement: Schritt 6, Bild 1 von 1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Microphone Replacement: Schritt 7, Bild 1 von 2 Palm Treo 650 Microphone Replacement: Schritt 7, Bild 2 von 2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Microphone Replacement, Motherboard: Schritt 8, Bild 1 von 3 Palm Treo 650 Microphone Replacement, Motherboard: Schritt 8, Bild 2 von 3 Palm Treo 650 Microphone Replacement, Motherboard: Schritt 8, Bild 3 von 3
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Palm Treo 650 Microphone Replacement: Schritt 9, Bild 1 von 2 Palm Treo 650 Microphone Replacement: Schritt 9, Bild 2 von 2
    • Pull off the motherboard.
  10. Palm Treo 650 Microphone Replacement, Keyboard: Schritt 10, Bild 1 von 1
    • Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
  11. Palm Treo 650 Microphone Replacement: Schritt 11, Bild 1 von 1
    • Pull off the circuit board.
  12. Palm Treo 650 Microphone Replacement: Schritt 12, Bild 1 von 1
    • Remove the keypad for cleaning or replacing.
  13. Palm Treo 650 Microphone Replacement, Microphone: Schritt 13, Bild 1 von 1
    • Place the circuit board with the microphone facing up.
  14. Palm Treo 650 Microphone Replacement: Schritt 14, Bild 1 von 2 Palm Treo 650 Microphone Replacement: Schritt 14, Bild 2 von 2
    • Pop the microphone off with your finger.
Abschluss
cgood
134 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 19-3, Maness Fall 2009 Mitglied von Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Mitglieder
18 Anleitungen geschrieben
1 Kommentar zur Anleitung
Step 14,replace the microphone,but can't recoder sound,because its hole been blocked。
linlance - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 22
Insgesamt: 4,691
