Zum Hauptinhalt wechseln
Palm Treo 680 Back Panel Replacement
Was du brauchst
  1. Palm Treo 680 Back Panel Replacement, Battery: Schritt 1, Bild 1 von 2 Palm Treo 680 Back Panel Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Back Panel Replacement, Back Panel: Schritt 3, Bild 1 von 2 Palm Treo 680 Back Panel Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Back Panel Replacement: Schritt 4, Bild 1 von 2 Palm Treo 680 Back Panel Replacement: Schritt 4, Bild 2 von 2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Back Panel Replacement: Schritt 5, Bild 1 von 1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 Back Panel Replacement: Schritt 6, Bild 1 von 3 Palm Treo 680 Back Panel Replacement: Schritt 6, Bild 2 von 3 Palm Treo 680 Back Panel Replacement: Schritt 6, Bild 3 von 3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 6-4, Maness Fall 2009 Mitglied von Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 34
Letzte 30 Tage: 76
Insgesamt: 3,348
