Einleitung
This guide shows how to repair a disfunctional Palm Treo 680 LCD Screen/Touch Screen.
Ersatzteile
Keine Ersatzteile angegeben.
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
Remove the 27mm screw using the T6 Torx screwdriver.
Turn the phone so the screen is facing the right side.
Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
Separate the covers from the left side of the device as indicated in the picture.
Take the front the pannel and notice that the screen is attached by a piece of silver tape.
Using a pair of tweezers, carefully peel off this piece of silver tape.
Remove the screen from the front pannel.
Obtain a small metal spudger and flip up the 2 tiny plastic flaps that hold the tiny orange ribbons in place.
Do the same thing for the other flap on the opposite side.
Flip the screen over a 180 degrees and take off the metal piece that cushions the screen.
Flip the screen over another a 180 degrees and place pressure on the bottom ribbon (Where my left thumb is).
Slightly Pull apart the touch screen from the LCD screen by placing your thumbs where my thumbs are. DO NOT PULL THE TWO SCREENS COMPLETELY APART YET.
Move your thumbs to the other corner of the screen and repeat the same procedure in step 9.
Carefully peel the touch screen away from the LCD screen.
Now you should have both the touch screen and LCD screen detached from one another.
2 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
where can i get the new touch scree, actually my mobile has fallen down and broken the touch scree. i am a resident in India, Andhra Pradesh, Hyderabad........at Ramkote.... please give me message at chinthala.prasad@yahoo.com please
These are very nice instructions. They are clear and detailed for anyone to follow. Thanks for putting together the steps and sharing it.
I have not tried all steps completely yet. But will do so. I will left with probably a question what to do with touch screen. My phone has
never fallen down nor damaged. It worked perfectly well and one fine day, touch screen stopped working. In any case, I will try.
RJ
