Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
How to replace the keyboard on your Palm Treo Pro
  1. Press down and forward on the back case to slide it out of place and remove it Press down and forward on the back case to slide it out of place and remove it Press down and forward on the back case to slide it out of place and remove it
    • Press down and forward on the back case to slide it out of place and remove it
  2. If a battery is already installed, remove it by pulling up on the tab near the camera lens.
    • If a battery is already installed, remove it by pulling up on the tab near the camera lens.
    • Insert the new battery into the open rectangle. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens
  3. Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone. Be careful not to misplace these screws as they are very small and will be important during reassembly. If the screws are stripped a flat head screw driver may be necessary.
    • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
    • Be careful not to misplace these screws as they are very small and will be important during reassembly.
    • If the screws are stripped a flat head screw driver may be necessary.
  4. Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera. Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera. Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
    • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
  5. Remove the main plastic body Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone. The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
    • Remove the main plastic body
    • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
    • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
  6. Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone. Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard. Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
    • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
    • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
  7. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  8. Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables. Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
    • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
  9. There are two ribbon cables under the yellow tape. Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable. To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
    • There are two ribbon cables under the yellow tape.
    • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
    • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
  10. Use a plastic opening tool to lift the motherboard up and out of the phone case There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone It can easily be disconnected with your fingers
    • Use a plastic opening tool to lift the motherboard up and out of the phone case
    • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
    • It can easily be disconnected with your fingers
    • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
    • The motherboard has now been completely removed
  11. Use the plastic opening tool to pry the side of the display glass up so you can easily remove it with your hand. Note: The display glass is the metallic rectangle with a orange ribbon cable attached to it.
    • Use the plastic opening tool to pry the side of the display glass up so you can easily remove it with your hand.
    • Note: The display glass is the metallic rectangle with a orange ribbon cable attached to it.
  12. Locate the four tabs above the keyboard. The following steps will demonstrate how to remove the metal plate from the tabs, which will reveal the keyboard. Locate the four tabs above the keyboard. The following steps will demonstrate how to remove the metal plate from the tabs, which will reveal the keyboard. Locate the four tabs above the keyboard. The following steps will demonstrate how to remove the metal plate from the tabs, which will reveal the keyboard.
    • Locate the four tabs above the keyboard. The following steps will demonstrate how to remove the metal plate from the tabs, which will reveal the keyboard.
  13. Insert plastic opening tool as shown and lift up to remove from tabs. You should hear a 'pop' and then feel the plate become loose.
    • Insert plastic opening tool as shown and lift up to remove from tabs. You should hear a 'pop' and then feel the plate become loose.
  14. Insert plastic opening tool as shown and lift up to dislodge plate from tab. Insert plastic opening tool as shown and lift up to dislodge plate from tab.
    • Insert plastic opening tool as shown and lift up to dislodge plate from tab.
  15. Insert the plastic opening tool between the metal plate and the bottom of the phone as shown. Note that for this step, inserting the plastic opening tool between the two circled tabs as shown will remove the plate from both of the tabs.
    • Insert the plastic opening tool between the metal plate and the bottom of the phone as shown. Note that for this step, inserting the plastic opening tool between the two circled tabs as shown will remove the plate from both of the tabs.
  16. The metal plate should now be loose enough to where one can remove the metal plate with either the plastic opening tool or with one's hands. Remove the metal plate and the keyboard beneath it can be easily removed. The metal plate should now be loose enough to where one can remove the metal plate with either the plastic opening tool or with one's hands. Remove the metal plate and the keyboard beneath it can be easily removed.
    • The metal plate should now be loose enough to where one can remove the metal plate with either the plastic opening tool or with one's hands. Remove the metal plate and the keyboard beneath it can be easily removed.
  17. Rotate the phone cover so that the face of the cover is facing up as shown in picture two. The keyboard should fall out from the keyboard holes. Rotate the phone cover so that the face of the cover is facing up as shown in picture two. The keyboard should fall out from the keyboard holes.
    • Rotate the phone cover so that the face of the cover is facing up as shown in picture two. The keyboard should fall out from the keyboard holes.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Dom Porcincula
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 8-59, Johann Spring 2013 Mitglied von Cal Poly, Team 8-59, Johann Spring 2013
CPSU-JOHANN-S13S8G59
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 175
