Einleitung
In this repair guide it will be described how to replace a broken screen on a Palm Vx orgainizer.
Was du brauchst
Pry off each side individually using a plastic pry bar.
Repeat for front and back of PDA.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
Now you must flip up the adjacent clamp as well, using tweezers like before.
After the clamp is flipped you can gently remove the second ribbon with tweezers.
Before removing the screen you must detach one more wire, the battery connector.
Using the tweezers, squeeze the connector attached to the wire and genlty pull.
Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
