Einleitung
Use this guide to replace a screen on a Palm Zire 21
  1. Remove the two 0.8mm screws located on the back of the device. Remove the two 0.8mm screws located on the back of the device.
    • Remove the two 0.8mm screws located on the back of the device.
  2.   Using tweezers, or something similar flip up the tab, releasing the wires located under the flap   Using tweezers, or something similar flip up the tab, releasing the wires located under the flap   Using tweezers, or something similar flip up the tab, releasing the wires located under the flap
    •  Using tweezers, or something similar flip up the tab, releasing the wires located under the flap
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Using a Philips head screwdriver, remove the two screws located at the bottom of the board. Using a Philips head screwdriver, remove the two screws located at the bottom of the board.
    • Using a Philips head screwdriver, remove the two screws located at the bottom of the board.
  5. Gently, remove the motherboard by lifting up exposing the screen. Gently, remove the motherboard by lifting up exposing the screen.
    • Gently, remove the motherboard by lifting up exposing the screen.
  6. Carefully, remove the screen from the device by lifting up and replacing with a new one. Carefully, remove the screen from the device by lifting up and replacing with a new one.
    • Carefully, remove the screen from the device by lifting up and replacing with a new one.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jeremy Craft
301 Reputation
3 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2014 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Fall 2014
USFSM-STEWART-F14S1G1
3 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 195
