Einleitung
This guide will teach you how to replace the audio on your Palm Zire m150. If you don't need to replace it, it will also teach you how to take the device apart in order to clean the control button.
Was du brauchst
Remove both screws on the back.
Turn screw driver counterclockwise to remove screw
Remove the front part of the device from the bottom part of the device.
Separate front cover from back cover.
Insert NEW audio piece into the top case housing.
On the NEW audio piece, use a soldering iron to solder.
