Einleitung
The Palm Zire m150 may sometimes need a motherboard replacement depending on the diagnosis. This guide will teach you how to replace that motherboard if that is the remedy needed after going through the troubleshooting steps.
Was du brauchst
Lift up the flap on the Palm Zire M150.
If you wish to remove it, gently lift up and pull horizontally. It should come off without an issue.
Take the screwdriver from the IFixit toolkit and use the T6 bit. Unscrew the the top two 3mm screws above where the flap was connected to the device.
Carefully remove the battery by prying up away from the motherboard.
Remove the positive and negative terminals from the motherboard.
Slowly remove the motherboard by lifting upward and out of the bottom case housing.
Insert NEW motherboard into the bottom case housing.
On the NEW motherboard, use a soldering iron to solder the positive and negative terminals to the new motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
