Einleitung
If the front and/or rear cover is cracked, this guide will teach the user to remove the damaged cover and replace with a new one.
Was du brauchst
Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
