Einleitung
If the front and/or rear cover is cracked, this guide will teach the user to remove the damaged cover and replace with a new one.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the batteries.
    • Remove the batteries.
  2. Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover. Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover. Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
    • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
  5. Set aside broken cover, and replace with a new cover.
    • Set aside broken cover, and replace with a new cover.
  6. Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
    • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
  7. Put the back cover on the device and screw the four screws, screwing in a clockwise direction.  Take caution not to over-tighten the screws.
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Abschluss
Anne Carey
1 Reputation
3 Anleitungen geschrieben
James Madison, Team 1-3, Allen Fall 2011 Mitglied von James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 471
