Zum Hauptinhalt wechseln
Palm m 100 Display Screen Replacement
Was du brauchst
  1. Palm m 100 Display Screen Replacement, Display Screen: Schritt 1, Bild 1 von 1
    • Remove the batteries.
  2. Palm m 100 Display Screen Replacement: Schritt 2, Bild 1 von 1
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Display Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove rear cover by gently lifting it up from the bottom.
  4. Palm m 100 Display Screen Replacement: Schritt 4, Bild 1 von 1
    • Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
    • Lift the left side of the circuit board and open it as though it were a book.
  5. Palm m 100 Display Screen Replacement: Schritt 6, Bild 1 von 1
    • Unplug the three connectors located on the right side of the circuit board with great caution and care. Do not pull by the cable, and be sure to pull the connector itself gently.
    • After separating the screen from the board, set aside the old display screen.
    • Replace with a new display screen.
  6. Palm m 100 Display Screen Replacement: Schritt 9, Bild 1 von 1
    • Plug in the three connectors.
  7. Palm m 100 Display Screen Replacement: Schritt 10, Bild 1 von 1
    • Close again like a book, and lay it gently into the front panel, screen facing outwards of the front panel.
  8. Palm m 100 Display Screen Replacement: Schritt 11, Bild 1 von 1
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Abschluss
Lexi Gallucci
11 Reputation
2 Anleitungen geschrieben
James Madison, Team 1-3, Allen Fall 2011 Mitglied von James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 685
