Zum Hauptinhalt wechseln
Palm m105 Batteries Replacement
  1. Palm m105 Batteries Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Press the latch on the battery door on the back of the device and pull outwards.
    • Back the device up if possible, you may lose all your data if there is no power for a little too long for it to retain it, make sure this is done quickly.
  2. Palm m105 Batteries Replacement: Schritt 2, Bild 1 von 1
    • Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
    • Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
  3. Palm m105 Batteries Replacement: Schritt 3, Bild 1 von 1
    • Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
Abschluss
Erik Thompson
31 Reputation
5 Anleitungen geschrieben
UW Stout, Team 1-3, Zhou Fall 2011 Mitglied von UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
Gene Merritt - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 1,226
