Zum Hauptinhalt wechseln
Einleitung
Replacement parts can be hard to find. The case on the m105 can be easily removed, and a replacement shell casing can be used to replace your damaged one. Check out this site here to buy a replacement.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the protective flip lid of the device. Open lid and pull. There are two clips that will pop out.
    • Remove the protective flip lid of the device. Open lid and pull. There are two clips that will pop out.
  2. Next, remove the plate on the top of the device. There is a tab at the top that un- clips and allows you to remove the face plate.
    • Next, remove the plate on the top of the device. There is a tab at the top that un- clips and allows you to remove the face plate.
  3. Remove the batteries by opening the battery compartment on the back of the device. Remove one battery at a time.
    • Remove the batteries by opening the battery compartment on the back of the device. Remove one battery at a time.
  4. Using a T-5 Torx screwdriver, remove all four screws at the back of device by turning counterclockwise. Screwdriver located here. Using a T-5 Torx screwdriver, remove all four screws at the back of device by turning counterclockwise. Screwdriver located here.
    • Using a T-5 Torx screwdriver, remove all four screws at the back of device by turning counterclockwise. Screwdriver located here.
  5. Once the four screws are removed, you are able to remove the back and front cover from the interior parts of the device. Once the four screws are removed, you are able to remove the back and front cover from the interior parts of the device. Once the four screws are removed, you are able to remove the back and front cover from the interior parts of the device.
    • Once the four screws are removed, you are able to remove the back and front cover from the interior parts of the device.
  6. This is what the case of the device should look like when compleated.
Abschluss
Travis
4 Reputation
1 Anleitung geschrieben
UW Stout, Team 1-3, Zhou Fall 2011 Mitglied von UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 7
Insgesamt: 640
