Einleitung
A brief description on how to remove the logic board
Ersatzteile
Kein Ersatzteil erforderlich.
Heat the left and top edges with hairdryer for one minute.
Move hairdryer back and forth to evenly heat up surface.
Use tweezers to hold Palm right side down on it's side.
Use a plastic opening tool to pry open front and back casing.
Leave plastic opening tools in between front and back casing.
Rotate Palm and repeat steps 2 and 3 for right and back edges.
Now pry open front and back casing with plastic opening tools.
Separate front and back casing completely.
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
Now you must flip up the adjacent clamp as well, using tweezers like before.
After the clamp is flipped you can gently remove the second ribbon with tweezers.
Before removing the screen you must detach one more wire, the battery connector.
Using the tweezers, squeeze the connector attached to the wire and genlty pull.
Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
Lift up the black flap covering the ribbon cable with your hand
With the spudger, left green cable clamp
Gently remove ribbon cable from clamp
