Zum Hauptinhalt wechseln
Panasonic ARC ES-LT3N Battery Replacement
Was du brauchst
  1. Panasonic ARC ES-LT3N Battery Replacement, Back Casing: Schritt 1, Bild 1 von 2 Panasonic ARC ES-LT3N Battery Replacement, Back Casing: Schritt 1, Bild 2 von 2
    • Flip the razor over so the back is facing you.
  2. Panasonic ARC ES-LT3N Battery Replacement: Schritt 2, Bild 1 von 2 Panasonic ARC ES-LT3N Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
  3. Panasonic ARC ES-LT3N Battery Replacement: Schritt 3, Bild 1 von 2 Panasonic ARC ES-LT3N Battery Replacement: Schritt 3, Bild 2 von 2
    • Slide the plastic cover at the bottom of the razor downward to remove.
  4. Panasonic ARC ES-LT3N Battery Replacement: Schritt 4, Bild 1 von 2 Panasonic ARC ES-LT3N Battery Replacement: Schritt 4, Bild 2 von 2
    • Lift up the rear casing from the bottom of the razor.
    • This may require you to gently pry it apart with you fingers.
    • Lift up the rear casing from the sides of the razor.
    • Pull rear casing up and off razor.
    • Be careful not to break any plastic!
  5. Panasonic ARC ES-LT3N Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
  6. Panasonic ARC ES-LT3N Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove battery case.
  7. Panasonic ARC ES-LT3N Battery Replacement: Schritt 7, Bild 1 von 2 Panasonic ARC ES-LT3N Battery Replacement: Schritt 7, Bild 2 von 2
    • Remove old battery by lifting the battery up and left.
    • There are plastic brackets holding the battery on the right. Removing up and left ensures that the brackets will not be damaged and the battery will not come loose.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S8-G3, Catania Spring 2017 Mitglied von UMass Dartmouth, Team S8-G3, Catania Spring 2017
UMASSD-CATANIA-S17S8G3
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Where does one actually find the replacement batteries though?
WooKstah - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,698
