Einleitung
This repair guide will show you the best step by step procedure of how to replace your battery in your Panasonic ARC ES-LT3N. The process is fairly easy and you only need a one tool!
Was du brauchst
Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
Lift up the rear casing from the bottom of the razor.
Lift up the rear casing from the sides of the razor.
Pull rear casing up and off razor.
Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
2 weitere Personen haben diese Anleitung absolviert.
