Zum Hauptinhalt wechseln
Panasonic CF-31 Toughbook Keyboard Replacement
Was du brauchst
  1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: Schritt 1, Bild 1 von 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: Schritt 1, Bild 2 von 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Open the battery compartment by pulling the tab forward and then down.
    • Open the compartment door by pushing down.
    • Use the plastic tab to pull the battery out of the compartment.
  2. Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 2, Bild 1 von 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the three screws from the bezel.
    • Use a nylon spudger to remove the bezel.
  3. Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 3, Bild 1 von 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 3, Bild 2 von 2
    • Use a nylon spudger to lift each corner of the keyboard.
    • Use your hands and gently pull back to remove the keyboard.
  4. Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 4, Bild 1 von 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
    • Remove the keyboard shield.
  5. Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 5, Bild 1 von 1
    • Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
  6. Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 6, Bild 1 von 1
    • Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
  7. Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 7, Bild 1 von 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: Schritt 7, Bild 2 von 2
    • Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
Abschluss
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
Richard Gill
145 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019
USFSM-STEWART-S19S1G1
18 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 45
Insgesamt: 2,408
