Einleitung
This is a guide for replacing a keyboard on the Panasonic CF-31 Toughbook laptop. The Panasonic CF-31 laptop is a fully rugged laptop designed to operate in environments not suitable for your normal laptop, such as extreme heat and cold, rain, dust, and a drop from a height of six feet or under. These conditions can cause components like the keyboard to malfunction, causing a need to repair or replace the keyboard. This repair guide will outline the steps to replacing the keyboard on the Panasonic CF-31 Laptop, the tools needed, and a list of parts needed to complete the repair.
Was du brauchst
Open the battery compartment by pulling the tab forward and then down.
Open the compartment door by pushing down.
Use the plastic tab to pull the battery out of the compartment.
Use a Phillips #2 screwdriver to remove the three screws from the bezel.
Use a nylon spudger to remove the bezel.
Use a nylon spudger to lift each corner of the keyboard.
Use your hands and gently pull back to remove the keyboard.
Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
Remove the keyboard shield.
Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
