Einleitung
Be sure to remove the battery and SD card before opening the camera to get to the screen component.
Was du brauchst
Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
Then, rotate the screen 180 degrees and remove the screw on the opposite side.
Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
Pull the screen away from the camera the same way that you removed the screen backing.
