Was du brauchst
First, before powering off, press the eject button to open the tray.
Remove the front cover of the tray.
Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
Then slide it vertically up and away.
Press eject button to close the tray.
Make sure to unpower and unplug device before continue work on other fixes.
Locate 6 tabs across the device.
2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
Remove the one green andthree blue tabs pictured that connect the disk drive to the board. Try to do so carefully, to avoid damage to the hardware.
Carefully take the drive out of the device. Note where the feet need to go back in for reassembly.
To reassemble your device, follow these instructions in reverse order. Ensure the feet of the disk drive go back in the holes.
