Zum Hauptinhalt wechseln
Panasonic DMP-BD89 Exterior Cover Replacement
Was du brauchst
  1. Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: Schritt 1, Bild 1 von 2 Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: Schritt 1, Bild 2 von 2
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 2, Bild 1 von 3 Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 2, Bild 2 von 3 Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 2, Bild 3 von 3
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 3, Bild 1 von 2 Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 3, Bild 2 von 2
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: Schritt 4, Bild 1 von 2 Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: Schritt 4, Bild 2 von 2
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 5, Bild 1 von 1
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 6, Bild 1 von 3 Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 6, Bild 2 von 3 Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 6, Bild 3 von 3
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Exterior Cover Replacement: Schritt 7, Bild 1 von 1
    • Pop the 6 markers out.
    • Then take off the cover.
Abschluss
David Sun
213 Reputation
2 Anleitungen geschrieben
UC Santa Barbara, Team S2-G9, Weedon Fall 2017 Mitglied von UC Santa Barbara, Team S2-G9, Weedon Fall 2017
UCSB-WEEDON-F17S2G9
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 247
