Einleitung
If the wireless features of your device are malfunctioning, replacing the WiFi board may resolve the issue. Follow this guide to learn how to remove and replace the WiFi board.
Was du brauchst
First, before powering off, press the eject button to open the tray.
Remove the front cover of the tray.
Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
Then slide it vertically up and away.
Press eject button to close the tray.
Make sure to unpower and unplug device before continue work on other fixes.
Locate 6 tabs across the device.
2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
Locate reddish brown cable. Detach from green circuit board by pulling upward.
Pull the module board straight up, removing completely. The second photo is how your device should look with the WiFi board removed.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
