Einleitung
Removal of the Panasonic DVD-RV31 outer case is necessary to gain access to the mainboard and other components. Removing the outer case is required to perform any other repairs in following Panasonic DVD-RV31 guides.
Was du brauchst
Eject the disk tray from the DVD player before removing power supply.
Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
Remove the three screws running along the back edge of case cover.
Remove the two screws from each side of the case cover.
Grab edges of the cover with your hands. Pull outward slightly, then straight up.
Eine weitere Person hat diese Anleitung absolviert.
