Einleitung
This guide will show you the preliminary steps you must perform before replacing EB-GD88 cellphone's camera and screen assembly.
Was du brauchst
Remove 4 rubber covers on the corners of the cellphone screen by prying them off with flat end of nylon spudger.
Using a Y0 tri-wing screwdriver, found in the 54 bit driver kit, remove the two screws above the screen. Twist the screws counterclockwise to remove.
Using a Y0 tri-wing screwdriver, remove the two screws below the screen. Twist the screws counterclockwise to remove.
Insert nylon spudger or curved tweezers into small gap between the phone's outer gray casing and the inner gray plastic compartment (which holds the green circuit board and screen together). This gap is indicated by red arrows.
Use the tools as leverage to pop out inner gray compartment unit (screen, gray plastic, and circuit board) away from the phones outer casing .
