Was du brauchst
Remove 4 rubber covers on the corners of the cellphone screen by prying them off with flat end of nylon spudger.
Using a Y0 tri-wing screwdriver, found in the 54 bit driver kit, remove the two screws above the screen. Twist the screws counterclockwise to remove.
Using a Y0 tri-wing screwdriver, remove the two screws below the screen. Twist the screws counterclockwise to remove.
Insert nylon spudger or curved tweezers into small gap between the phone's outer gray casing and the inner gray plastic compartment (which holds the green circuit board and screen together). This gap is indicated by red arrows.
Use the tools as leverage to pop out inner gray compartment unit (screen, gray plastic, and circuit board) away from the phones outer casing .
On the circuit board, release the two connector ribbons holding the screen to the circuit board. To do this use tweezers to disconnect both the off-white connector piece and the white connector piece.
Remove disconnected screen from phone.
Attach new screen to circuit board. To reassemble your device, follow these instructions in the reverse order.
