Zum Hauptinhalt wechseln
Panasonic ER-GN30-K Blade Replacement
  1. Panasonic ER-GN30-K Blade Replacement, Blade: Schritt 1, Bild 1 von 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Blade Replacement: Schritt 2, Bild 1 von 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  3. Panasonic ER-GN30-K Blade Replacement: Schritt 3, Bild 1 von 1
    • Remove the blade from the cap by gently pulling it from the cap.
    • Even if the blade is dull or broken, it will still be sharp enough to cut skin, so be careful while you remove it.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 15-3, Blackwell Fall 2015 Mitglied von USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Mitglieder
5 Anleitungen geschrieben
6 Kommentare
Looked everywhere...anybody know where to get replacement blades for the Panasonic ER-GN30 nose & ear trimmer?
R Holmes - Antwort
Did you ever find a replacement blade?
PCARRINGTON - Antwort
I called Panasonic's support number, and supposedly the inner blade at least, is priced from around $14 to $20, from various places. Considering major resellers have the whole trimmer for around $12, it would not make sense to get just a blade. Amazon has open-box wearhouse deals now, where the trimmers can be had for under $5.00. I may get one of these myself :)
Jim Locke - Antwort
Hola yo acabo de comprar las cuchillas a 7€ , les dejo el enlace https://juanluismartel.com ademas me repararon una camara Panasonic Lumix, Gracias.
usblsb - Antwort
still looking
jorgensen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 42
Insgesamt: 12,969
