Zum Hauptinhalt wechseln
Panasonic ER-GN30-K Motor Shaft Replacement
Was du brauchst
  1. Panasonic ER-GN30-K Motor Shaft Replacement, Motor Shaft: Schritt 1, Bild 1 von 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Shaft Replacement: Schritt 2, Bild 1 von 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Shaft Replacement: Schritt 3, Bild 1 von 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Shaft Replacement: Schritt 4, Bild 1 von 1
    • The motor shaft should be sticking out from the top of the device.
    • Use the metal prying tool to pry apart the silver plastic case .
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Shaft Replacement: Schritt 5, Bild 1 von 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Shaft Replacement: Schritt 6, Bild 1 von 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Shaft Replacement: Schritt 7, Bild 1 von 2 Panasonic ER-GN30-K Motor Shaft Replacement: Schritt 7, Bild 2 von 2
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
Abschluss
USF Tampa, Team 15-3, Blackwell Fall 2015 Mitglied von USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
Aurimas Miko - Antwort
Dear Alejandro,
thank You for your instruction, my question is where this motor shaft part is available? I can’t find it anywhere on the net. Thanks if you can help. Bence Fazekas
fazebence - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,567
