Zum Hauptinhalt wechseln
Panasonic ER430K Battery Replacement
Was du brauchst
  1. Panasonic ER430K Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Panasonic ER430K Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the battery cover by rotating it counter -clockwise and lifting it off.
    • Tilt the trimmer to the bottom, you will notice the battery housing.
  2. Panasonic ER430K Battery Replacement: Schritt 2, Bild 1 von 1
    • Insert the AA Battery according to the terminals on the Battery housing.
    • Note the '+' side in the the housing and the '-' side on the cover.
  3. Panasonic ER430K Battery Replacement: Schritt 3, Bild 1 von 1
    • Twist the battery cover housing in a clockwise direction to secure the the battery.
Abschluss
IUPUI, Team S22-G2, Bayer Fall 2017 Mitglied von IUPUI, Team S22-G2, Bayer Fall 2017
IUPUI-BAYER-F17S22G2
4 Mitglieder
3 Anleitungen geschrieben
2 Kommentare
Battery + side goes in first (when battery is inserted correctly, the - side will be facing you).
Marc2 Salvisberg - Antwort
i prided the negative tab on the cover up to make contact. the trimmer roared to life again!
Dean Jarvis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 66
Insgesamt: 4,456
