Zum Hauptinhalt wechseln
Panasonic ES-RF31 Battery Replacement
Was du brauchst
  1. Panasonic ES-RF31 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Panasonic ES-RF31 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Panasonic ES-RF31 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Loose the screw at the bottom part of the razor
  2. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: Schritt 2, Bild 1 von 3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: Schritt 2, Bild 2 von 3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: Schritt 2, Bild 3 von 3
    • Slide the cover from top to bottom
  3. Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: Schritt 3, Bild 1 von 2 Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: Schritt 3, Bild 2 von 2
    • Loosen these eight screws
  4. Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: Schritt 4, Bild 1 von 2 Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: Schritt 4, Bild 2 von 2
    • Insert an opening tool into the gap
    • Gently remove the battery cover
  5. Panasonic ES-RF31 Battery Replacement, Removing the Battery: Schritt 5, Bild 1 von 2 Panasonic ES-RF31 Battery Replacement, Removing the Battery: Schritt 5, Bild 2 von 2
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Daniel
934 Reputation
2 Anleitungen geschrieben
iFixit EU Team Mitglied von iFixit EU Team
Staff
47 Mitglieder
1.090 Anleitungen geschrieben
4 Kommentare
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Nils Kay - Antwort
Hello Nils!
Thanks for the hint.
Glad to hear that your razor works again!
Greetings
Daniel - Antwort
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
Виктор Богачёв - Antwort
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
David Paul - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 100
Insgesamt: 5,803
