Zum Hauptinhalt wechseln
Panasonic GU87 LCD Cover removal Replacement
Was du brauchst
  1. Panasonic GU87 LCD Cover removal Replacement, LCD Cover removal: Schritt 1, Bild 1 von 1
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Panasonic GU87 LCD Cover removal Replacement: Schritt 2, Bild 1 von 1
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
Abschluss
Van
7 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 2-10, Johann Summer 2010 Mitglied von Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,614
