Zum Hauptinhalt wechseln
Panasonic HC‑VX870 Record Button Replacement
Was du brauchst
  1. Panasonic HC‑VX870 Record Button Replacement, Side Cover: Schritt 1, Bild 1 von 3 Panasonic HC‑VX870 Record Button Replacement, Side Cover: Schritt 1, Bild 2 von 3 Panasonic HC‑VX870 Record Button Replacement, Side Cover: Schritt 1, Bild 3 von 3
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Record Button Replacement: Schritt 2, Bild 1 von 2 Panasonic HC‑VX870 Record Button Replacement: Schritt 2, Bild 2 von 2
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Record Button Replacement, Record Button Mechanism: Schritt 3, Bild 1 von 1
    • Unscrew the indicated screw.
  4. Panasonic HC‑VX870 Record Button Replacement: Schritt 4, Bild 1 von 1
    • Lift up on the little tab indicated in the picture and push away from the camera in order to remove the record button.
  5. Panasonic HC‑VX870 Record Button Replacement: Schritt 5, Bild 1 von 3 Panasonic HC‑VX870 Record Button Replacement: Schritt 5, Bild 2 von 3 Panasonic HC‑VX870 Record Button Replacement: Schritt 5, Bild 3 von 3
    • Take out the piece that that was held in place by the screw and separate the smaller piece from the larger piece.
Abschluss
Cal Poly, Team 13-6, Banghart Winter 2017 Mitglied von Cal Poly, Team 13-6, Banghart Winter 2017
CPSU-BANGHART-W17S13G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 465
