Einleitung
The hand-strap of the Panasonic HDC-TM15 allows the user to safely handle and stabilize the camera during use. Replacing it is a straightforward process and easy to do!
Was du brauchst
Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
Once all eleven screws have been removed, put your hand through the hand-strap and tug on the side cover until it comes off completely.
Unscrew the two silver .5 mm Phillips #00 screws located in the bottom corners of the inside of the side cover. This will release the two silver plates that hold the hand-strap in place.
Pull the hand-strap through the holes of the side cover, until it is completely detached.
Set the old hand-strap aside.
Taking your new hand-strap, first feed the smaller loop through the bottom right hole of the side cover.
Feed the hooked end of the smaller silver plate through the first loop of the new hand-strap.
Slide the sliver plate into place, lining up the screw holes, and screw in tightly.
Feed the larger loop through the hole in the opposite corner of the side cover.
Feed the U-shaped silver plate through the second, larger loop of the new hand-strap in the opposite corner of the side cover.
Ensure the screw hole is lined up.
Tug on the hand-strap to ensure it is securely in place.
If your new hand-strap feels secure, you can now re-attach the side cover to your camcorder.
When the side cover is securely fastened, you have completed the hand-strap replacement of your Panasonic HDC-TM15 camcorder.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Any idea where the replacement strap can be purchased? Thank you
