Zum Hauptinhalt wechseln
Panasonic HDC-TM15 Record Button Replacement
Was du brauchst
  1. Panasonic HDC-TM15 Record Button Replacement, Record Button: Schritt 1, Bild 1 von 1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Record Button Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Record Button Replacement: Schritt 3, Bild 1 von 3 Panasonic HDC-TM15 Record Button Replacement: Schritt 3, Bild 2 von 3 Panasonic HDC-TM15 Record Button Replacement: Schritt 3, Bild 3 von 3
    • Once all eleven screws have been removed, put your hand through the hand-strap and tug on the side cover until it comes off completely.
    • The inside of your camcorder should now be completely exposed, as shown in the photos.
  4. Panasonic HDC-TM15 Record Button Replacement: Schritt 4, Bild 1 von 2 Panasonic HDC-TM15 Record Button Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the two 1 mm Phillips #00 black screws in the corners of the green memory card reader.
    • The screws should be surrounded by orange circles.
  5. Panasonic HDC-TM15 Record Button Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the black 1 mm Phillips #00 black screw in the left center beside the green motherboard.
  6. Panasonic HDC-TM15 Record Button Replacement: Schritt 6, Bild 1 von 2 Panasonic HDC-TM15 Record Button Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the 1.2 mm Phillips #00 black screw beneath the motherboard on the bottom of the camcorder.
    • The green motherboard should now be partially detached, as shown in the photo.
  7. Panasonic HDC-TM15 Record Button Replacement: Schritt 7, Bild 1 von 3 Panasonic HDC-TM15 Record Button Replacement: Schritt 7, Bild 2 von 3 Panasonic HDC-TM15 Record Button Replacement: Schritt 7, Bild 3 von 3
    • Remove the long silver plate that secures the record button.
  8. Panasonic HDC-TM15 Record Button Replacement: Schritt 8, Bild 1 von 1
    • Remove the old record button from beneath the silver plate.
  9. Panasonic HDC-TM15 Record Button Replacement: Schritt 9, Bild 1 von 2 Panasonic HDC-TM15 Record Button Replacement: Schritt 9, Bild 2 von 2
    • Place the new Record button into the open slot.
  10. Panasonic HDC-TM15 Record Button Replacement: Schritt 10, Bild 1 von 2 Panasonic HDC-TM15 Record Button Replacement: Schritt 10, Bild 2 von 2
    • Slide the silver plate into place beside the new Record button.
    • Ensure that the Battery Eject button is lined up properly.
  11. Panasonic HDC-TM15 Record Button Replacement: Schritt 11, Bild 1 von 2 Panasonic HDC-TM15 Record Button Replacement: Schritt 11, Bild 2 von 2
    • Re-screw the green motherboard into place and re-attach the side cover to your camcorder.
    • When the side cover is securely fastened, you have completed the Record Button replacement of your Panasonic HDC-TM15 camcorder.
Abschluss
Emma
176 Reputation
1 Anleitung geschrieben
Marist, Team 1-4, Laflen Spring 2015 Mitglied von Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 273
