Zum Hauptinhalt wechseln
Panasonic HDC-TM15 Side Cover Replacement
Was du brauchst
  1. Panasonic HDC-TM15 Side Cover Replacement, Side Cover: Schritt 1, Bild 1 von 1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Side Cover Replacement: Schritt 2, Bild 1 von 1
    • Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Side Cover Replacement: Schritt 3, Bild 1 von 3 Panasonic HDC-TM15 Side Cover Replacement: Schritt 3, Bild 2 von 3 Panasonic HDC-TM15 Side Cover Replacement: Schritt 3, Bild 3 von 3
    • By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
    • Once the old cover is completely detached, set it aside.
    • The inside of your camcorder should now be completely exposed, as seen in the photos.
  4. Panasonic HDC-TM15 Side Cover Replacement: Schritt 4, Bild 1 von 2 Panasonic HDC-TM15 Side Cover Replacement: Schritt 4, Bild 2 von 2
    • Line up the new side cover in the exact same place, ensuring that the screw holes match.
    • Re-screw the side cover into place.
  5. Panasonic HDC-TM15 Side Cover Replacement: Schritt 5, Bild 1 von 1
    • Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
    • When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tricia Fallo
210 Reputation
2 Anleitungen geschrieben
Marist, Team 1-4, Laflen Spring 2015 Mitglied von Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 308
