Einleitung
Using this guide, a Panasonic HDC-TM15 owner will be able to remove the broken side cover of the camcorder and replace it with a new one.
Was du brauchst
Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
Once the old cover is completely detached, set it aside.
The inside of your camcorder should now be completely exposed, as seen in the photos.
Line up the new side cover in the exact same place, ensuring that the screw holes match.
Re-screw the side cover into place.
Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
