Zum Hauptinhalt wechseln
Panasonic HDC-TM90 Lens Clean
Was du brauchst
  1. Panasonic HDC-TM90 Lens Clean, Battery: Schritt 1, Bild 1 von 1
    • Open the LCD screen.
  2. Panasonic HDC-TM90 Lens Clean: Schritt 2, Bild 1 von 1
    • Slide the battery release switch away from the battery.
  3. Panasonic HDC-TM90 Lens Clean: Schritt 3, Bild 1 von 1
    • While holding the switch away from the battery, push the battery out of the slot.
  4. Panasonic HDC-TM90 Lens Clean: Schritt 4, Bild 1 von 1
    • Remove the battery from the camera.
  5. Panasonic HDC-TM90 Lens Clean, Panasonic HDC-TM90 Lens Clean: Schritt 5, Bild 1 von 3 Panasonic HDC-TM90 Lens Clean, Panasonic HDC-TM90 Lens Clean: Schritt 5, Bild 2 von 3 Panasonic HDC-TM90 Lens Clean, Panasonic HDC-TM90 Lens Clean: Schritt 5, Bild 3 von 3
    • Remove 5 screws from the side panel body of the camcorder.
    • Use the spudger to remove the top of the camcorder.
  6. Panasonic HDC-TM90 Lens Clean: Schritt 6, Bild 1 von 2 Panasonic HDC-TM90 Lens Clean: Schritt 6, Bild 2 von 2
    • Unscrew three screws to remove the lens rim on the front of the camcorder.
    • Be aware of the wires attaching the lens rim to the body of the camcorder. You will not be able to separate the lens rim completely.
    • Use caution when separating the shutter lever.
  7. Panasonic HDC-TM90 Lens Clean: Schritt 7, Bild 1 von 1
    • Remove the rubber ring around the lens.
  8. Panasonic HDC-TM90 Lens Clean: Schritt 8, Bild 1 von 1
    • Unscrew the lens by removing the three screws connected to it.
Abschluss
Tyler Jaynes
1 Reputation
2 Anleitungen geschrieben
Baylor, Team 8-4, Whitney Spring 2017 Mitglied von Baylor, Team 8-4, Whitney Spring 2017
BU-WHITNEY-S17S8G4
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Steps 1-4: good pre-req
Step 5-bullet 1: Which screwdriver and how many screws? There seem to be a lot of screws so perhaps numbering how many and where they came from would be helpful. Maybe color coding your steps with more details using markers of how many screws and what location in the pictures would be helpful.
Step 5 bullet 1 and 2 should probably be 2 separate steps.
Step 5- bullet 2: could use a picture
Step 6: Did not seem to be how we did this step at all. Perhaps this could be explained in much more detail with more detailed pictures. Also the cautions and warnings should be labeled as such.
Rene Klopf - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 495
