Zum Hauptinhalt wechseln
Panasonic KX-TG6021M Front Speaker Replacement
Was du brauchst
  1. Panasonic KX-TG6021M Front Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 Panasonic KX-TG6021M Front Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Panasonic KX-TG6021M Front Speaker Replacement: Schritt 2, Bild 1 von 3 Panasonic KX-TG6021M Front Speaker Replacement: Schritt 2, Bild 2 von 3 Panasonic KX-TG6021M Front Speaker Replacement: Schritt 2, Bild 3 von 3
    • Pull the top of the battery towards you to remove it from the phone.
  3. Panasonic KX-TG6021M Front Speaker Replacement, Front Panel: Schritt 3, Bild 1 von 2 Panasonic KX-TG6021M Front Speaker Replacement, Front Panel: Schritt 3, Bild 2 von 2
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Panasonic KX-TG6021M Front Speaker Replacement: Schritt 4, Bild 1 von 3 Panasonic KX-TG6021M Front Speaker Replacement: Schritt 4, Bild 2 von 3 Panasonic KX-TG6021M Front Speaker Replacement: Schritt 4, Bild 3 von 3
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Panasonic KX-TG6021M Front Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
  6. Panasonic KX-TG6021M Front Speaker Replacement, Front Speaker: Schritt 6, Bild 1 von 1
    • Remove the front speaker housing by detaching it from the circuit board.
  7. Panasonic KX-TG6021M Front Speaker Replacement: Schritt 7, Bild 1 von 1
    • Pop out the front speaker from the housing.
  8. Panasonic KX-TG6021M Front Speaker Replacement: Schritt 8, Bild 1 von 1
    • Desolder the two connections and remove the wires from the circuit board.
Abschluss
IUPUI, Team 3-1, Baechle Fall 2016 Mitglied von IUPUI, Team 3-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 214
