Einleitung
Use this guide to correctly replace the display screen on one of the handsets for your Panasonic phone. Display screens may become cracked or dysfunctional due to normal wear or accidents. By replacing the display, users will be able to operate features such as caller ID more easily.
Was du brauchst
In order to remove the back of the phone, unscrew the two screws at the bottom corners on the back of the phone.
In order to remove the back of the phone, pry the back open by inserting the iFixit Opening tool in the space between the front and back of the phone.
Remove the earpiece cover by twisting the plastic earpiece clockwise to unlock.
Replace earpiece by heating wires with soldering iron.
Solder wires back to earpiece after installing the replacement earpiece.
Unscrew two screws at the bottom of the motherboard in order to remove.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Thanks it makes it very easy
Where to buy the screen in India?
