Einleitung
Use this guide to correctly repair damaged or loose wires in your Panasonic phone. Loose or damaged wires can lead to functions such as speakerphone not operating correctly, as well as calls being dropped completely. If damaged, replacing the wires is necessary to keep the phone functioning.
If you need help with soldering, review how to solder and desolder connections.
Was du brauchst
Identify damaged or loose wires. If loose, adjust till properly placed. If damaged, solder the new wire(s) to the mother board or desired location.
