Zum Hauptinhalt wechseln
Panasonic KX-TGE233 Base Front Panel Assembly Replacement
Was du brauchst
  1. Panasonic KX-TGE233 Base Front Panel Assembly Replacement, Base Front Panel Assembly: Schritt 1, Bild 1 von 1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: Schritt 2, Bild 1 von 1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: Schritt 3, Bild 1 von 1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: Schritt 4, Bild 1 von 1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: Schritt 5, Bild 1 von 1
    • With the back removed, we now have direct access to all other components in the main docking station.
Abschluss
IUPUI, Team 2-2, Baechle Spring 2016 Mitglied von IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 303
