Zum Hauptinhalt wechseln
Einleitung
Steps for removing the back half of the case and replacing it with a new one.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Panasonic Lumix DMC-F7 Back Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the lock into the unlocked position to the right.
    • Use your finger to slide battery hatch towards the arrow sign.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Back Case Replacement: Schritt 2, Bild 1 von 1
    • Open battery hatch and the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Pull the battery out and replace with a new one.
    • When putting the battery back in, make sure it is in the same orientation as before.
    • Close the battery compartment and make sure the lock is in the locked position.
  3. Panasonic Lumix DMC-F7 Back Case Replacement, Back Case: Schritt 3, Bild 1 von 1
    • Remove the two 2.8 mm Phillips screws.
  4. Panasonic Lumix DMC-F7 Back Case Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Back Case Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture.
  6. Panasonic Lumix DMC-F7 Back Case Replacement: Schritt 6, Bild 1 von 2 Panasonic Lumix DMC-F7 Back Case Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger to pry open the case from all sides.
  7. Panasonic Lumix DMC-F7 Back Case Replacement: Schritt 7, Bild 1 von 2 Panasonic Lumix DMC-F7 Back Case Replacement: Schritt 7, Bild 2 von 2
    • Beware of the ribbon cable that is still attached when opening.
    • Use your fingers to carefully pry off the back casing from the camera assembly.
  8. Panasonic Lumix DMC-F7 Back Case Replacement: Schritt 8, Bild 1 von 1
    • Lay the camera on its front side. Use the spudger to open the film strip locking mechanism and remove strip.
    • Hold down on the camera's metal casing with one hand. Use your other hand to completely lift the back case off the rest of the camera, making sure the film strip separates.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Alex Penman
463 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 7-35, Regan Winter 2011 Mitglied von Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 807
