Einleitung
Fixing the lens apparatus on your camera.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Open battery hatch and the black cover to expose the battery compartment.
Pull the battery out and replace with a new one.
Close the battery compartment, and make sure the lock is in the locked position.
Remove the two 2.8 mm Phillips screws as shown in picture.
Using a Philips Screw Driver, remove the three 2.8 mm Phillips screws on the bottom of the camera as shown in picture.
Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture.
Use your fingers to carefully pry off the back casing from the camera assembly.
Lay the camera on its front side./combine this sentence to the step below.
Use Spudger tool to open the film strip locking mechanism and remove strip./No edits necessary.
Hold down on the camera's metal casing with one hand. Using your other hand, completely lift the back case off the rest of the camera, making sure the film strip separates./Make a picture for this step.
Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
Using Spudger tool, pry the front case from the camera's components.
Use your fingers to carefully pull the back case from the front case.
Cut the black and red wires connecting front case to the body of the camera.
Be careful nothing gets caught, and separate the front case from the camera.
Check the "V" shaped spring to see if it is connected.
Manually move the lens apparatus from the inside to shown position.
Check to see if the spring is aligned correctly and the lens opens.
If not, you will need to take out the spring and place it into the proper position, or get a new spring all together.
Ein weiterer Nutzer hat diese Anleitung absolviert.
