Zum Hauptinhalt wechseln
Panasonic Lumix DMC-F7 Front Case Replacement
Was du brauchst
  1. Panasonic Lumix DMC-F7 Front Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 2, Bild 1 von 1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Front Case Replacement, Back Case: Schritt 3, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 5, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 6, Bild 1 von 2 Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 7, Bild 1 von 2 Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 7, Bild 2 von 2
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 8, Bild 1 von 1
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
  9. Panasonic Lumix DMC-F7 Front Case Replacement, Front Case: Schritt 9, Bild 1 von 1
    • Remove the last two 2.8 mm Phillips #00 screws from the bottom of the camera.
  10. Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 10, Bild 1 von 3 Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 10, Bild 2 von 3 Panasonic Lumix DMC-F7 Front Case Replacement: Schritt 10, Bild 3 von 3
    • Using the spudger, pry the front case away from the camera's components.
    • Use your fingers to carefully pull the back case from the front case.
    • Cut the black and red wires connecting front case to the body of the camera.
    • Be careful to ensure that internal materials won't be caught.
    • Separate the front of the case from the camera.
    • To reinstall the front case, solder the wires of the new case to the components of the camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alex Penman
463 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 7-35, Regan Winter 2011 Mitglied von Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 823
