Einleitung
If you’ve cracked the screen or are experiencing issues with the screen of your Panasonic Lumix DMC-F7 digital camera, it may be time for a replacement. To complete this replacement, you will need to know how to solder. You will also need a few tools, so be sure to check the Tools List below before starting this replacement. This guide will help you properly replace the LCD (liquid crystal display) screen for the Panasonic Lumix DMC-F7 digital camera.
Ersatzteile
Keine Ersatzteile angegeben.
Slide the lock into the unlocked position to the right.
Use your finger to slide battery hatch towards the arrow sign.
Open battery hatch and the black cover to expose the battery compartment.
Pull the battery out and replace with a new one.
Close the battery compartment and make sure the lock is in the locked position.
Use a Phillips screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture.
Use your fingers to carefully pry off the back casing from the camera assembly.
Lay the camera on its front side. Use the spudger to open the film strip locking mechanism and remove strip.
Hold down on the camera's metal casing with one hand. Use your other hand to completely lift the back case off the rest of the camera, making sure the film strip separates.
Use a spudger to lift the screen ZIF connector tab.
Use the back of the spudger to push the ribbon cable free.
Use the screwdriver to remove the four 2.4 mm Phillips screws.
Lift up the LCD screen from the front case.
Locate the wire connecting the LCD screen to the motherboard.
Use the soldering iron to desolder the wire.
Use the soldering iron to solder wires from new LCD screen to the circuit board.
Ein weiterer Nutzer hat diese Anleitung absolviert.
