Zum Hauptinhalt wechseln
Panasonic Lumix DMC-FH20 LCD Screen Replacement
Was du brauchst
  1. Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 3 von 3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 LCD Screen Replacement: Schritt 3, Bild 1 von 2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 LCD Screen Replacement: Schritt 4, Bild 1 von 2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Unscrew one screw (Phillips #000 head).
  6. Panasonic Lumix DMC-FH20 LCD Screen Replacement: Schritt 6, Bild 1 von 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: Schritt 6, Bild 2 von 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 10-7, Banghart Winter 2017 Mitglied von Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 517
