Zum Hauptinhalt wechseln
Panasonic Lumix DMC-FX07 Back Cover Replacement
Was du brauchst
  1. Panasonic Lumix DMC-FX07 Back Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 2, Bild 1 von 2 Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 Back Cover Replacement, Memory Card: Schritt 3, Bild 1 von 1
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Panasonic Lumix DMC-FX07 Back Cover Replacement, Back Cover: Schritt 4, Bild 1 von 2 Panasonic Lumix DMC-FX07 Back Cover Replacement, Back Cover: Schritt 4, Bild 2 von 2
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 5, Bild 1 von 2 Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 6, Bild 1 von 3 Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 6, Bild 2 von 3 Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 6, Bild 3 von 3
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 7, Bild 1 von 3 Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 7, Bild 2 von 3 Panasonic Lumix DMC-FX07 Back Cover Replacement: Schritt 7, Bild 3 von 3
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
Abschluss
Karissa
50 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 6-23, Amido Spring 2012 Mitglied von Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 1,399
